I just got daemon tools pro, and i'm not very familiar with it although alot of it is self explanatory. It says it accepts .iso files to mount. I have an iso file made by poweriso which i downloaded, it works fine when i extract it but i cannot add the iso. When i try to add it or find it daemon just pretends it doesn't exist as if it's in the wrong format but it's a poweriso file, why isn't it working, and what should i do cause i want to mount this image.
ISO file trouble
ISO file trouble
I have daemon tools pro. I have a game i want to mount. It was made into an image by poweriso. When i go to properties it says file type is poweriso, and daemon tools is compatible with .iso files. When i try to search for images or when i try to add an image, daemon doesn't show my poweriso image, as if it's not compatible. Does anyone know why it doesn't work and how i get my image to mount.
