I'm using Vista, and I have been using DT 4.09 until like a week ago when I upgraded to the lite version (4.120). I tired to mount .img files on Daemon, and it didn't work. It says it's mounting, then it never loads it on the tray. I tried with different files, but it still won't work. So I got the newest version from this site and tried it again, and it's still not working. Other file types work just fine. Does anybody know why?
.img file won't mount on Vista
i meant shared drives as network.. ie: not mounting from local drives, or drives physically attached on the pc...
if it only happens on img files, i wouldnt worry, just convert img->iso should do the job.. img files (and iso files) are crap for protection information ... so if your disks are copyprotected and you make an iso/img from them its useless...my views are 100% personal views..
Allow me to explain why you won't get any help with a game you downloaded.Originally Posted by 0choi0 View PostI downloaded from a person's blog I know, and it works fine for other people. It's a game cd, and everything except mounting the image to run the game is working.
A) If it's a commercial game, that's called warez. And you wont' get any help from here. And might I suggest reading the rules if you have not done so already.
B) If it's a homebrew game for some old system, you still won't get any help because we don't know how the image was created, nor can you possibly recreate the image yourself.
Either way you cut it, you're on your own.
