Is there any possible way to mount the rzr-crysis image with any version of DT on the XP x64 OS?
I used to mount it just fine with the DTP 0218 and Win XP Pro (32 bit).
I've used the search function (a dozen times). Unfortunately the results are clogged with so much bullshit, I can't possibly sit here and read every single thread that was closely related to my search term but had nothing what-so-ever to do with the problem at hand.
If you post a thread that has the answer and should have been found with the search function, also post what your search term was and how close to the top the result was =)
Thanks in advance for any help / answers.
From what I can tell there is no way to mount rzr-crysis w/ DTP on XP x64
