Ok, I copied the ISO and mounted it on the false drive and installed the game just fine. But, when I tried to play it, it said "Please insert the correct DVD-ROM and click OK to restart application." I then got on Alcohol 120% and burned the Image on to a DVD (I had to go get double layer disks, costly I tell ya.) I now insert the disk, it loads up just like the DAEMON way, and still says the same thing when I click "play". What do I do now? My common sense has run out!
You can get the same torrent at
I am running windows vista home, Alcohol 120%, BitTorrent 6.0.3, DAEMON Tools Lite (4.12.2), Internet Explorer... what else do you need to know? I'll tell ya!
My first time, any help would be much, much appriciated.
