Hi
I have a data CD it's an application and i don't see any protection with any kind of CD-scanners it's build in the exe so it's not packed or somthing like that ..
this application comes with 2 CDs :
CD1- is installation. (no protection)
CD2- data CD of all DataBase of application - protected
in the protected CD there are 3 files with a XXX extension in root:
file00.xxx - 563,438 KB
file08.xxx - 850 KB
file09.xxx - 3KB
there is 2 more folders
MA folder files:
file08.MA - 1,054 KB
file09.MA - 36 KB
YZ folder files:
file08.yz - 361KB
file09.yz - 11KB
from what i have saw when i try to crack this when i'm running with an image of the CD i get an error from the application that this is not the original CD .
it check first to see if there is a debugger present and then it check a black list of virtual dirves to see if it run from a virtual CD after that it try to load the CD (daemon was not detected)...
I have patch the CD check with error message "not original CD" so it will continue to load from the image CD but application crashes when it try to run.
I don't understand (yet) why it fails to run from image.
I guess there is a signed key in the CD and it try to read and decrypt with that key the files from the CD so i need to digg deeper.
I have maked all possible images with Alcohol 120% at speed x1 and still it fails.
I Have made some google search and found that more ppl have same issues
with same protection
Defekte Sektoren ab 316687 - Club CDFreaks - Knowledge is Power
can anyone please have more idea about what i can do for this protection ?
Regards,
LaBBa
file08.xxx - 850 KB
file09.xxx - 3KB
MA folder files:
file09.MA - 36 KB
YZ folder files:
file08.yz - 361KB
file09.yz - 11KB
Regards,
LaBBa
