Error message "Insert disc'
  • Error message "Insert disc'
    Hi,
    I instal the games using daemons tools, then when i going to play the games asking to "insert correct CD ROM select ok or resart disc"
    Pls give me a solution.
    Kindly reply as soon as possbile
    Regards
    Dhayanidhi
    Which games are you installing?
    How have you created your images?
    What DAEMON Tools version are you running?
    What OS are you running?
      Well i have the same problem, and the problem is with all ISO's buth i looks like it started after the new DT update...
      DT v4.12.4
      Windows Vista Fully updated
        same problem, I installed Empire Earth III from ISO images using Daemon Tools Lite as the emulator. When I clicked play it says "Wrong disc, please insert correct CD/DVD" so then I installed and used YASU ALONG with:
        1st: I converted the original ISO into mds. using Safedisc as the datatype
        2nd: I converted the original ISO into mds. using SecuROM as the datatype
        both failed. I need help please!
          Recreate the image from your Original disk and choose SecuROM profile.
