Hi,
I tried to mount a language learning software on DT, and it seemed to install properly and opens up, but when i click on the icons an error message pops up saying either "System error: MCI error: There is no driver installed on your system" or "System error: Media not open". If i click 'ignore' on the message then the function actually works, but an error message pops up each time i click another icon as well. The programme is kinda useable, but it's just a bit of a hassle and annoying! Any help or tips would be much appreciated! (Another aspect of the software is that it comes on 5 discs - unzipped from a .rar file - when i unzip them it says they're all the same size and asks if i want to replace the existing file for each disc i unzip. Do i need to do anything in particular with this discs?)
Thanks
Thanks
