ok my freind gave me the program so i can play this game of his and he wrote a read me witch reads:
HW2 Setup
1. Copy folder 'DAEMON Tools Lite' and drop it anywhere.
2. Go into the folder you just placed, and double click the file 'daemon'.
- It is the one with the icon of the disk with a lightning bolt through it.
3. Go down to the bottom-right hand corner of your screen (Next to the clock)
and right click the green daemon tools symbol. Scroll up to the Virtual CD/DVD
ROM, select device 0, and then hit 'Mount image'
4. Select the file "homeworld_2.x-gamers-razor1911.sharereactor.cue" as your
mounted image.
5. The Homeworld 2 installation screen should come up, and when it asks you
for a CD key, enter this string: NAS3-DEC2-BYJ5-CUJ6-8385
6. If this CD key doesn't work, tell me, and I'll find a new one.
7. Enjoy.
i get down to number 2 and instalation error 2 pops up sayin i need windows 2000 with sptd 1.53 or higher and to deactivate kernel debugger. I have windows XP and im lost from there an anoyone help me
HW2 Setup
mounted image.
7. Enjoy.
