Help! Wich is the app to burn .bin images???
  • Help! Wich is the app to burn .bin images???
    Hi,
    I'm traying to burn a .bin image with Alcohol 120%, but it doesn't recognize that kind of files... even though, Alcohol could burn the image but requests me information about blocks size, image header size, and some other strange things... that of course, I never heard about. :oops: :oops:
    Does anyone know what application do I have to use to burn .bin files? or can anyone help me with Alcohol and thouse strange parameters?!? :?: :?:
    Thanks in advance.
    How did you make the image? A bin file requires a companion cue file.
      I didn't make de image, just downloaded fron internet. What do you mean with "companion" file?
      I don't know if it helps you, but the image worked when put it in a virtual drive with Virtual Daemon Manager. I could read and execute the files of the image from a virtual drive. I mean, is it possible without that companion file you mentioned?
      Thanks again.
        Funny, isn't it :roll:
