Screenshot - Into This place i marked with a red line - you should add something like "Type: Physical/Virtual" because i think it's a little bit stupid that when you mark your physical DVD - information about it will be displayed under "Virtual device info" (So it sound slike my physical DVD is a Virtual device
"Virtual device info" should also be renamed to "Device info".
Is it something you will work on?
)"Virtual device info" should also be renamed to "Device info".
