downloaded a program off the web, said I needed daemon tools or the like to install it. downloaded daemon lite, ran .cue file, prompted me to install, clicked install, started to run then said "program is not installed will exit setup", i click ok then it says "install shield wizzard has been interupted"... "the system is not modified"... "try again later"... and my only option is to click finish. can anyone help? I am not very good with computers so please keep it dumbed down for me. Thanks
