Problem in mounting .exe file
  • Problem in mounting .exe file
    I mounted an .exe file. It createed a virtual drive in my computer but when I click that drive it says :
    Windows cannot access this disc
    The disc might be corrupt. Make sure that the disc uses a format that Windows recognizes. If the disc is umformatted, you need to format it before using it.
    Please help me.
    Cheers,
    Maria
    Exe is not an image format.
      What do you mean? look, this is a game 'THe sims life stories'. I downloaded it from a torrent site. it was a 2.14 gb file. I read its instruction for how to install the game. It said that you've to mount this sd4hide.exe & then install it. Now temme what should I do?
