Mentioning Crack -- post from DTLite e Securom 7.40 thread
  • Mentioning Crack -- post from DTLite e Securom 7.40 thread
    Originally Posted by wilander View Post
    @khornesaturnine
    Not risk anything, to restore those registry keys simply reboot, however the keys:
    "Driver" = "ai5xksd9" (the value of this key is changing on every configuration, but is recognized because it is a series of letters and numbers)
    "Interrupt" = dword: 00000009 (probably the value is always the same)
    are always found in the directory HKEY_LOCAL_MACHINE \ HARDWARE \ DeviceMap \ Scsi \ SCSI Port X, X is a variable and then the folder can be Scsi Port 0/1/2/3 etc. ... you have got to find.
    Hello.
    dang...i tried what you said to do and im still unable to play divinity 2 with the no cd crack.
