I downloaded a .zip or .rar or something, decompressed, and found a .cue and .epm (or something like that) file staring back at me. I knew that Daemon Tools could run .cue, so I loaded it up.
"Unable to load file. File not accessible."
Oh, great. So I scoured the internet. It seemed that .cue files work with .bin files. Okay...well the file had .bin.epm on it, so I stripped the .epm from it.
So I decided to try it out. Loaded it into Daemon Tools and...nothing. I didn't expect it to do much, as it's a PlayStation disc image and my computer's not a PlayStation. So I right-clicked on the icon to make sure the image was mounted.
Nothing. I can't get the menu to come up. What's worse is that when I go into Computer (I'm on Vista, so no "My Computer") and right click on the Daemon Tools drive, IT freezes up as well (the Windows Explorer menu). Furthermore, I can't get Taskmanager to pop up so I can force-close Daemon Tools.
This, as you can tell, is a problem, and I'm not sure what the problem is, exactly. Could I just have a bad image, or am I doing something wrong otherwise?
