GTA IV disc check
  • GTA IV disc check
    Oh
    But that doesn't matter any more.
    I've found a No-CD crack for GTA IV
    GTA_IV_Crack_NO-CD_1.0.0.4.zip
    It's clean (according to Norton Internet Security 2009), and it works.
    The "GTA_IV_Crack_NO-CD_1.0.0.4.zip" file contains 5 files
    - GTAIV;exe
    - LaunchGTAIV.exe
    - Logo.dll
    - Paul.dll
    - READ-ME.txt
    Code:
    ---------THIS CRACK WORK 100% PERFECT OF LAST UPDATE GTA IV V1.0.0.4 / 1.0.5.0----------
    This is the CRACK FOR PLAY GTA IV ONLINE OR OFFLINE YOU CAN PLAY NO CD/DVD ( PLAY WITHOUT CD-ROM/DVD-ROM ) THIS CRACK WORK IN ALL THE VERSIONS ( 11/16/2009 ) [ 1.0.0.0 ; 1.0.1.0 ; 1.0.2.0 ; 1.0.3.0 ; 1.0.4.0 ; 1.0.0.4 OR 1.0.5.0 ]
    		INSTALL
    IF THIS IS YOUR FIRST DOWN THIS CRACK EXTRACT ALL THE FILES TO MAIN FOLDER OF GTA IV ( D:\Arquivos de programas\Rockstar Games\Grand Theft Auto IV )
    THIS UPDATE CRACK FIX THE BUG ON MISSION OF VLAD, IF YOU HAVE THE CRACK AND WORK BUT HAVE THE BUG IN MISSION OF VLAD YOU NEED JUST TO PUT IN MAIN DIRECTORY GTA IV FOLDER ONLY THE ONE FILE ( PAUL.DLL )
    Make By Ness
    [Pirata]Ness
    LIVE ID:  Nessfrg
    The Paul.dll doesn't need to be replaced if you don't want to, I tried it out witouth replacing the file and it works fine. (Ofcourse if it doesn't work out well, you need to replace the paul.dll file as well)
    I hope I can help some of you with this.
