this never happened with my old pc im currently running on win 7 64 bit now when i mount the image nothing happens the installation is suppose to pop up but it doesnt i tried daemon lite and now im using daemon pro and suggestions? im trying to mount this game but for some reason nothing happens when i mount the image
Automount isn't the same as Autorun/Autoplay.
Autmount means that an image is mounted automatically when DAEMON Tools is launched.
From here on the OS is responsible whether to Autorun or not.
Does the installation pop up with the original disc ATM ?
P.S.: some apps e.g. virus scanners can alter the Windows Autorun settings; please search the web on how to check those settingsI'm not employed by Disc Soft and my views do not necessarily reflect the ones of the company.
Can you browse the content of the mounted image in Computer/Windows-Explorer ?
No matter whether you mount manually or let the image automount, it doesn't change the Autoplay behaviour of the OS.Originally Posted by willg0r View Post...so how do i turn on automount?
How to change those settings:
Change AutoPlay settingsI'm not employed by Disc Soft and my views do not necessarily reflect the ones of the company.
Where is that image located ?Originally Posted by willg0r View Postnope nothing i mount it to the virtual drive it doesnt even show at all
Other images are working ok ?
How have you created that image ?I'm not employed by Disc Soft and my views do not necessarily reflect the ones of the company.
its located in the winrar folder where the games are but yeah i mount it like how i usually do it but it doesnt work on this computer for a reason when i had my old computer it worked fine with no errors this is a first and this is the first time i installed a game on my new comp through torrents
