hello,
I've downloaded these 2 mdf and 2 mds files. These are images of 2 vcds. And because alcohol 120% won't work on my pc I've always mount these images and do a cdcopy with nero. So I've tried to burn with dics 1 but it failed. I've got an error. So tried to burn disc2 and burned it with no problem at all. There must be something wrong with the file I think.
Now I want to know is there something I can do to fix the file?
Is there a way convert them to cue/bin or wouldn't it change anything at all?
The only alternative I can think off is to mount the image and copy the dat file and burn as vcd with nero. But that means I will lose the trackoption.
Any help is welcome.
thank you
thank you
