Hello!
I have bought Sacred and i have made Virtual CDґs with Virtual CD, it havent worked.With Deamontools it didnt work, too !
I sanned the File and i found that !!
Some have to make a Stealth Version or a Patch which disable this Protection.
THX
____
Sry 4 my Englisch, i am From Germany !
Code:
Scanning -> G:\Games\Sacred\Sacred.exe File Type : Exe, Size : 3597638 (036E546h) Bytes -> File has 2400662 (024A196h) bytes of appended data starting at offset 01243B0h [!] VOB Protect CD v0.4 detected ! - Scan Took : 0.312 Seconds
THX
____
