Operating System: Windows XP
Burning Software: Nero
Anti-virus Software: Norton 2002
DAEMON Tools Version: 3.46
Hi,
I just downloaded Daemon and installed without any trouble, but i dont know what to do now. I mount a .iso file to a drive that Daemon created, but then i dont know hwat to do.
When idouble click on the drive i mounted my .iso file on, it give the error message:
Disk is not formatted
Windows cannot read from this disk. The disk might be corrupted, or it could be using a format that is not compatible with windows.
So i need some serious help.
Thanks if you provide support.
Hi,
