I have C&C Generals that isnt a 1:1 copy and I try to use daemon-tools but it doesnt work, says pleas insert correct cd-rom. So my question is does daemon-tools support safedisc v2.80.xx and higher? And do I need a 1:1 copy to load it with daemon-tools? And say i DO need a 1:1 copy, is there a program that can make a non-1:1 copy into a 1:1 copy (or something close)?
Big question
if you can awnser this that would be great!
Thanks
Big question
if you can awnser this that would be great!Thanks
