I have to use a nocd patch for my dungeon siege backup to work and the game will run without the cd. Now I wanted to use dsmod.exe from the Dungeon Siege Tool Kit, but it keeps asking me to insert disk 1 and I put the copied cd in...then it still asks me to insert it!:x I also tried making a cd image from the disk onto the hardrive and running it in daemon tools testing all 4 Emulations, plus a 5th try with all 4 selected at once.. but all of these failed and the game still asked for disk 1. Is there a way I can remove the copy protection from the dsmod.exe file so I can run the game in that mode?
You see, dsmod allows you to load an edited .dsparty file into you current single player game and have modifyed stats..thus then saving your game after that to confirm it back to single player.
any help would be greatly appreciated! :wink:
