Operating System: windows xp
Burning Software: alcohol 120
Anti-virus Software: norton
DAEMON Tools Version: 3.46
I was wondering if once you make a perfect image of game you own on cd you can then just play the game without the cd, or if you need to install the game first then mount the image. Also can you install the game just using D-tools and the image you made from the cd??
