Operating System: win xp
Burning Software: alcohol 120
Anti-virus Software: norton
DAEMON Tools Version: 3.46
I was wondering if you can install a game just using the mounted image with d-tools after making the image using alcohol 120?? or do you need to install the game and then you can play it using the image and d-tools?? help would be appreciated..
