Hi,
ok i got these 2 cd of my friend (Its call of duty united offensive game)
and he said i need this program called daemon tools, so i downloaded it and i put the both cd in seprate drives and i right click on the icon down on the tool bar and go virtual cd/dvd rom then i go down and select set number of devices and i do it to 2 so then i click on Mount image and then i browse and go into the cd and select the mo-cdufa.cue and there is 2 other files there and thay r mo-cdufa.bin, and mo-cdufa.sfv so i click on the .cue file and then it mounts the image, then it brings up the auto install thing and i mount the other image file on the second disc thats in my other cd rom drive, then they r both mounted then i click install on the auto install thing it stars to install then it get 2 a certain point then a error message come up and that says 1628:Failed to complete the installation, but my friend done the same thing i did and it worked for him but not me, so plz help me, (btw do u have to have dvd drives to use this program)
Thanks chris
Thanks chris
