Operating System: Windows 2003 Server Enterprise edition, evaluation version
Burning Software: Nero 5.5.10.56
Anti-virus Software: Sophos Anti-Virus v3.87
DAEMON Tools Version: 3.46
Hi!
I have a CD image, which if mounted, gives a read error on a file ( REAMDE.TXT ).
If I try to open it in notepad, I get a read error dialog.
"TYPE README.txt" in in command line print some part of the file without any error message.
"TYPE README.txt > c:\temp\x.txt" on the other hand gives an error.
If I burn the image to a CD-RW, then it read the file fine, no errors whatsoever.
I also tried older versions of daemon tools. Same result.
I don't have the image file at hand right now, but I think you can get it here :
ed2k://|file|cd1.cue|125|B38406F6C734701BFB5FEF77BE68958A |/
ed2k://|file|cd1.BIN|814944480|DF5D70EEAD33F1DCAC3B37206D ADD8BC|/
Hi!
