I have this game and want to keep my original as pristine as I can. Therefore, I want to create a copy that I can mount in Daemon to play the game.
I entered the serial from the original that I created as a .mdf image. After mounting it in Daemon Tools 3.46, it fails to validate the CD with the serial. I've even tried an exhaustive search for a fix for this and found only another serial which also fails to work. :cry:
There is a registry workaround for the Starforce protection I believe but searching has found no references in the forums. I was going to try it to see if it would work. Can anyone point me to the relevant thread in the forums for this?
Thanks.
Thanks.
