Mounted game (i think) what now?
  • Mounted game (i think) what now?
    Operating System: Windows XP
    Burning Software: CloneCD
    Anti-virus Software: Zonealarm Antivirus
    DAEMON Tools Version: 3.47
    I've successfully installed Daemon Tools and have mounted Harvest moon.
    I mounted harvestmoon.ccd and got a folder coming up with a group of files.
    the files are:
    • A_FILE.BIN
      A_FILE.HDT
      ABSTRACT.TXT
      BIBLIOGP.TXT
      COPYRIGH.TXT
      DUMMY.DAT
      SLUS_011.15
      SYSTEM (Speeddial?? It has "Speeddial" beneath it)
    there is also a folder called STR which has 01, 02, 03 and 04.XA
    Now that I have all this bumpf on the mount, what do I do with it? What other programs do I need to run the game?
    How did you create the image, what kind of game if is it?
      I downloaded it from Home Of the Underdogs.
      It was a ccd file I got in a zip.
      You'll learn which technologies are right for your business and will help you increase sales, speed up transactions, reduce labor costs and protect your data.
      I right clicked the tray icon, went to virtual CD/DVD ROM and mounted harvest moon back to nature.ccd
      That was when all the aforementioned files and stuff appeared in a window.
      BTW, HOTUD is NOT an illegal site/warez etc. All the stuff they put up are either abandonware or they have permission to put up for free/purchase. Just so there isn't any mistake.
      EDIT: to add
      It is a playstation image. You should be able to d/load it and take a look yourself.
