I have a copy of the rosetta stone language program and cant get it to work. I mounted the image file like all teh directions say and i get nothing. If anyone could help me id really appreciate it.
Rosetta Stone
1) You need:
- Rosetta Stone - Application v2.0.6A
- Rosetta Stone - <<<YOUR LANGUAGE>>>
- Daemon Tools download from: http://www.daemon-tools.cc/portal/download.php
2) you unpack the rar files (get iso files)
3) and put in some directory
4) Install daemon for mounting iso files (if you haven't done yet)
after restart of computer you will have the daemon icon in the system tray (lower right)
right click on it,
select menu Virtual CD/DVD-Rom, and
select first voice mount image
and search the application iso (this will create a virtual drive)
5) Autorun should start now the virtual CD and you can install now the base program
6) mount now the other image (no autorun in this case, just ignore)
7) and launch now the rosetta stone program from the start menu
I did that and got an iso file. I mount it and i get a window popping up asking me what program i want to open it with.
