This game has Securom protection and Im not sure what I should do, did few things that I know but none of them worked because of the spiral data track which Securom uses as protection.
The file was in .bin format and I used Isobuster to extract the files to a folder Empire Earth II. I used Deamon tools to maunt the image of the original Empire Earth II.bin and then I mounted the image using Isobuster and the file was in .iso format. I also used Nero to burn the Empire Earth II.iso to a disk but after all that I can only get to the Main Menu of the game and click play game. then i get message saying please insert valid disk...
Where should I go from now, heard Alcohol 120% is the only program that can successfully create an images of the Securom protected cds.
Thanx
Thanx
