Operating System: Windows XP Pro SP2
Burning Software: Nero 6
Anti-virus Software: Norton Systemworks 2005 Pro
DAEMON Tools Version: 3.47
Alright. So I read all the other complaints about this same thing from other people. I understand exactly what to do to fix it aswell. You take the original CD, pop it in your real drive, make image with Alcohol make sure its the .sdm or whatever, and you should be set, right?
What if you don't have the original CD and what you have is just an .iso? From what I understand once you burn it to an .iso image file the Protected data etc. is lost therefore it wont work. Somebody mentioned re-creating the image file. If the image file is already .iso then wouldn't the needed data already be lost? I am totally stumped and I need your help guys.
TIA
TIA
