Been lurking for a few days and reading. But now this is getting personal.
ENV
OS: WinXP SP2
CDR: Generic one that came with Dell. Some kinda Samsung
CDR Software Installed: Blindwrite 5.2.16.154, Alcohol v1.9.5.3105, Some flavour of Nero
Other: Daemon Tools 3.47
Game: Silent Storm Sentinels v1.1
Protection: Securom 5.x.008 + JoWood Xprot
ISSUE
After all longish spinning CD icon it tells me to bugger off and put in my original cd and/or goto to securom.com/copy
THINGS TRIED
Chronologically
Nero
1) create image with Nero
2) mount image with DT or reburn image and use DT emulation
3) Error result insert orginal disc
Scour the forums. read and use search function like fiend.
Blindwrite
1) Create BWA, BWT and BWI
2) mount with DT and burn image with BW and then do DT Emulation
3) Error result. Uninstall patin-couffin engine
4) disable said engine
5) Error result Insert orignal blah blah. Contact Securom.com/copy
Curse like sailor
All the while I've been trying different premutations of bypassing the blacklist when I use DT.
Blacklist Fixes Tried
1) Manual regedit
2) Hide_Virtual_CD.exe
3) rename regedit driver entry to "atapi"
Same error as above. Despite all the registry tricks the Jowood .exe is still able to blacklist the emulation or image. ie. image unmounted and/or emulation option disabled (RPMS)
Cursing like a HAIRY chested sailor now.
What else do I try?. I'll be damned if I have to uninstall my cdr apps.
cheers,
ed
ENV
OS: WinXP SP2
ISSUE
THINGS TRIED
Chronologically
Nero
Blindwrite
Curse like sailor
1) Manual regedit
cheers,
ed
