you can user a loader to play it online. someone used a diablo 2 and diablo 2 LoD loader program so you can play it multiplayer as well without a crack. i think the newest version of it requires at least a copied cd to be in the drive which kinda defeats the purpose because then you could juse use your proper cd :?
but anyway if you copied it off someone you wont be able to play it anyway :P and multiplayer is the only mode i play/worth playing
