Operating System: XP
Burning Software: Nero 6
Anti-virus Software: MaAfee
DAEMON Tools Version: 3.47
hi
have learned a lot from you guys thanks.. using daemon to mount .cue but am getting thru install to "insert disk 2" of install and it doesn't access the 2nd disk.... disk is fine, file is fine, burned with nero 6 (should it be clonecd or something?) .... disk 1 has .bin and .cue on there, as has disk 2 so i am wondering why the file doesn't continue to install? anyone...
thx
hi
thx
