Operating System: XP Pro
Burning Software: None
Anti-virus Software: Norton
DAEMON Tools Version: 3.47
Well I just got this bad boy and thought I was on my way. I got the install disc to run and it set up perfectly from a .ccd file. This game has 4 other Discs. After the intro and "New Game" was all done it says to insert Disc 1. So I change the mount to the .ccd file for disc 1 and another window pops up for the E:/ drive showing 5 files. I tried mounting one of those images in the E:/ and then tried the F:/ with the install disc mounted in E:/ to no avail. I also have a file .cue that I tried and a .img in that original Disc 1 file that did not work either.
The files that show up in this E:/ drive folder are .PAK, .FI, .FL, .FS, and one that just says Disc 1. That is a 1 KB file.
Basically i'm just trying to figure out how you get to the next step of the game with those files to start Disc 1, 2, 3, etc.
Any help would be great.
