Operating System: Pentium 4, 2.4 Ghz, 512 Ram, SP 2, RADEON 9600 XT 256 MB
Burning Software: Nero 5
Anti-virus Software: Norton Antivirus 2005
DAEMON Tools Version: 3.46
Hello!
I'm pretty new to this forum but not to the software...
I use DT a lot but I encountered a problem.
I downloaded Warhammer 40K: Dawn of War: Winter Assault (CloneCD's).
In the NFO file it says this:
"1.) Unrar, Burn Using BlindWrite 4.5.7 (disable Autoplay in Options menu) burn in DAO PW at 4-12x click "YES" when asked if you want to physically include BWA information.
Alternativley, you can mount the image in a120/dt.
2.)Install and Play.
3.) Have fun
I installed succesfully with the new patches and everything required (while using DT).
Now the problem is that when I mount the first disc (the Play Disc) and enter the game, it says that the CD isn't authenticated.
I saw that it doesn't work with DT or A120 so I decided to burn it with BlindWrite like the NFO file says.
In BW it tells me that the file (BWI/BWT) doesn't exist.
What do I need to do to play Winter Assault with DT?
Is there even an option to do it?
Thanks very much in advance!
Hello!
3.) Have fun
"I installed succesfully with the new patches and everything required (while using DT).
