Heres what I did. I have a bin/que of a game. I used winiso to make an iso of the game. My choice of burning iso to disk is Easy Cd Creator. When I was done all I had on the disk was the files from the bin/cue not the bootable disk (that i normally get) So I looked at the help file where the bin/cue is and it says to burn/mount using Daemon Tools. First I dont see an option to burn and when I mount it nothing happens except a command prompt pops up then goes away. When I tried to install the game from the setup exe i get an error saying (D:\Setup.exe The NTVDM CPU has encountered an illegal instruction.) I have no clue whats going on. I have always made iso and burned them to disk using Easy CD Creator and the game starts to install right off the bat. Nothing is happeing here. I have never used Daemon Tools therefore I have no clue what I'm doing. BTW I also tried to make a bootable disk using Alcohol 120 and I got the same error. Any advise would be much appreciated. Thanx
Lost like never before
