im not sure if this is a dumb question or not (its my first time using this program) but when i mount the image n then i goto that drive, all the .EXE files do not have icons and when i click them the MS-DOS prompt comes up for a second then goes away (so i cant run my setup files for b&W2) is there anything i can do to fix this problem, sorry if this is a dumb question
setup for B&W2 wont run
i'm having a similar problem. the images are good. the run fine on my roommates computer. they even ran once fine on mine but now they don't. they mount but then when i go to explorer it takes forever to open the drives and when i try and open so much as a text file it just says "cannot open blah.txt make sure the file exists" or some nonsense like that. i also tried it in alcohol. same problem.
