This post isn't only about Worms Mayhem but mostly about things I am still confused with. I'll use my recent strugle with Worms Mayhem to ask you a few things.
Lets say I have a Worms Mayhem ISO image and I am not able to make a new mds/mdf one (
). Will the senario bellow work?
a) I mount the image w/ DT 4.
b) Use Alcohol to extract mdf/mds image
c) Of cource .mds is worthless, so I dowload a new .mds from somewhere.
d) I mount the new image w/ DT 4 and I play Worms Mayhem.
-> Is there any chance that the above will work?
-> I must find a .mds file that matches my disk right (the one that used to take the ISO image)? Where can I find such a file? Is it legal?
-> Is there any way to tell if the .mds i dowloaded matches my image (using a prog or something)? I assume there are several version of Worms Mayhem or any game.
-> I've read about spikes in .mds files... How do you scan an .mds file for spikes?
-> If I find a .bwa file can I convert it to .mds?
Thats lot of question above. I hope someone will find the time to answer some (hopefully all) of the above
). Will the senario bellow work?a) I mount the image w/ DT 4.
