I installed alcohol so I can open the mdf files of the game, so I've got 4 files (the 4 cd's), and I start to open file cd 1. I get a window of Need for Speed where I can chose install and after that I also get the window where you can follow the status of the installation but then there's an error that it says it can't transfer the file "Music.mus" (or something like that), which is also the first file it should transfer. So what is the problem ?
