I have multiple Iso's. Sims 2, Simcity 4. One reads "elby.vcdmount.1" as their type (sims2). In Sims 2, when I try and Mount it, it says "please insert the correct cd-rom". When I insert the disk, it works. Now, on the other hand. I try Simcity 4, it works. I am Using Daemon tools 4.00.
Computer specs: Athlon 1900+
120gb hd
Mx4000 video card
Is there anyway to change the file type from elby.vcdmount.1 to something else? I uninstalled alcohol 120%, and every other virtual emulator. Every one failed. Please help
120gb hd
Mx4000 video card
