about 2 months ago i tried to install DT 4, or whatever the most current at the time was, its long gone, so i have no files that can tell me what it was
I was running a AMD 64, DT didnt work, obviously i was told it didnt run on a 64 bit system, now i try to install the new 64 bit version and i get an error that says
"the platform is not supported"
is this a common problem that can be fixed?
or could all my troubles be caused by my...um...lets just say...version of windows that should have stopped working....30 days after instalation....
