the Nfo says "Remove all IDE drives and Play"
as i understand its Starforce Nightmare..
i installed the game and download Sfn latest version
my computer is built like that:
Primary IDE Master Location 0 : NEC 3540A
Bus Number 0, Target ID 0, LUN 0 : Hard Disk (S-ATA II)
now i tried on Sfn the following choices:
Disable ch1 - computer Stuck /Restart
Disable ATA - computer stuck /Restart
Disable CD - Game not works
Disable Pr.Master - Game Not Works
tried to enter Device manager and disable CD/SCSI(DT) manualy
game not works... also
any help will be appricated?
(a friend is suggest me to move DVD-ROM to Secodery Master cause maybe the Sfn catchs the Primary with the Serial-ATA also..?)
Admin/MOD - Not sure if it the right location if not Delete-away
