hi i try loading a .iso file into DT 4.0 and the window comes up saying installing for a sec then goes away and it wont let me install at all. i have used DT before on .iso files and it has worked. any suggestions?
can i get some help on this or what? been days since i posted this question. anyone else have this problem? im trying to load splinter cell chaos theory and it starts to load to install it and then goes away im clueless.
If you'd posted in the correct forum, you'd probably got help earlier.
You can not play SCCT from ISO due to the protection used, re-create the image from original in appropriage image format.
