Hi everyone... i have some problems with the protection... so I have WinXp with SP2 ..i'm using alchool 120% version 1.9.2 (Build 1705) and sd4hide. The images that i mounted aren't mine so don't ask me information about how are made because i don't know.. And now the problem! The game runs... i play but at the end of the match when i have to go back to the menu, it brokes and return to Windows.. Do you have any suggestion? Is it possible that is the version of alchool the problem? or the images that i use? (if you have others made from you, you could send me..i would be very grateful!) so thanks a lot and have a nice day!
Skankster...
Skankster...
