Hi,
I've just downloaded a game, mounted it with Daemon Tools v4.0.
I enabled all emulation options, used SF Nightmare to disable "node", CD drive. I also need to disable IDE, but when I disable channel one I get bluescreened and channel 2 doesnt do anything. As I've read and looked across the net I see that this is the only way around Starforce, other than physically disconnecting wires. Is there a reason why I'm getting bluescreens, and is there any way around it?
Thanks.
Thanks.
