hi everyone;
i need some info regarding the game brian lara 2005. I installed the game using alcohol 120%. After installation its asked me to restart the system to complete installation & i did so. After it i run the Sfnightmare & i did the following things in the same sequence;
Disable node, disable cd, disable node.
Now when i run the game it asks me to give the disc key & i entered which was available in the readme file. It is not accepting that key & it shows me this messagae;
"Disc read error when checking disc.Make sure a licensed disc is in the drive, the disc isnot damaged & the valid Disc key is entered"
Can you kindly help me in this problem ? What should i have todo now ? where I went wrong ? Is there any easy method to run the game u could suggest ?
waiting for your reply
bye.
bye.
