Hi everyone
I have installed Matrix PON from the image and I got a guide alongwith it which told me to use daemontools, anti-blaxx and srs-stop to play the game.
but the game is not running.
following are the instructions that i followed:
1>installed the game
2>from daemontools mount the image
3>in anti blaxx > "settings". > use daemon tools
" at restore > after the game exits
at method> Hide entrys (Adminrights)
at protection > securom 7
game> matrix3.exe(address of the file)
use daemon tools > device 0 and give the address of the image
5. Now Start Daemon tools and mount " mir-pon.mds " and after that shut Down deamon tools
6. now Start "SR7.Stop_1.0.exe" and Press Restore and u will se Genetic DVD-ROM 1.0 Select it and Press hide
and now u will se somthing like "HIdde: d347.prt"
now it says to shut down daemon tools and anti blaxx , does it mean i have to just close it or remove it from the task bar completely?
also do i have to close SR7.Stop_1.0.exe after hiding the drive
plz help me in this case bcoz im dying to play this game
the error msgs that i get is > insert original dvd, emulator detected and security module coudnt be activated
plz plz plz help me
i have read many solns on this site using cdclone, virtual cd hide and all that win2k compatiblity but plz tell me one solution that really works
is there any patch to crack this game
7.Press at The Matrix - Path of Neo Shortcut and start the game and have fun!!
plz plz plz help me
