Hi,
I have a big problem with mounting. I can't mount Bin files witn any program i tried
. (Daemon Tools 4.0, Daemon Tools 3.47, Alcohol 120%) For example, I wanted to install Dawn of War from three bin files (on a dvd). For some reason that i don't know it was unsuccessful.
It says Datacab1 or 2 or 3 corrupted or wrong. That can't be. From the same dvd my friends made with Daemon Tools. I have one real cd and another dvd drive. It isn't a virus or malware. I converted the bins into Iso files with WinIso, but the problem is the same. Should i copy the bins to the winchester? I have copied oem xp professional.
Can you help me?
It says Datacab1 or 2 or 3 corrupted or wrong. That can't be. From the same dvd my friends made with Daemon Tools. I have one real cd and another dvd drive. It isn't a virus or malware. I converted the bins into Iso files with WinIso, but the problem is the same. Should i copy the bins to the winchester? I have copied oem xp professional.Can you help me?
