actually i had the same problem with rome - total war , even though i mounted it and managed to install it properly, they asked me to insert the right cd .
But there is a solution , download alcohol 120% and when u mount the image, explore the virtual cd created and u will find there a file - called crack . replace the crack exe with the reale application and it will work ! aint that simple ,
hope it will work for you guys
