problems with installing blitzkrieg 2...
heres the install notes:
1. Burn with Alcohol 120, at 4x speed( or more this does not
depend if it will work) , use securom NEW profile.
2 When asked, select "Keep TOC as on source cd,
write until end of image file"
3 Use the following cdkey:
4 alternative you can also sfcure this but we do not support
sfcure when a full retail burn can work just check a dvd release
on how to sfcure. One tip as this is a sf 3.4 version it does not
need to physically have the the cables removed from your drive on
the other hand you never know with sf
Next to that also SFN should work without sfcure to disable
drives but just use it to be sure.
Sidenote:
Recently we been attacked for releasing this so called by some
people crap.
This crap involves a lot of work even with the tool.
So if you don't like it don't leech it if you do and get it
working to enjoy the game we did
why cant i just mount it with daemon 4 and run the game?
i installed it fine, but when i start it up the exe wont run!
. Next to that also SFN should work without sfcure to disable
Sidenote:
people crap.
